goldeneaglesteam
Source file not found
can you help me to solve this issue?
Re: Source file not found
Can you please try to set the "ExtractFilesFirst" property to "1" in the "Properties" page, rebuild the project and see if that helps?
Please have a look on the
Source file not found error
thread which debates a similar (if not the same) problem.
goldeneaglesteam
please check the log: (it can't extract the presq. files
=== Verbose logging started: 28/04/43  19:44:29  Build type: SHIP UNICODE 5.00.10011.00  Calling process: E:\مجلد جديد\test_Full.exe ===
MSI (c) (CC:38) [19:44:29:001]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\SalesUp_6.8.0.2.msi' against software restriction policy
MSI (c) (CC:38) [19:44:29:001]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (CC:38) [19:44:29:001]: SOFTWARE RESTRICTION POLICY: C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\SalesUp_6.8.0.2.msi is not digitally signed
MSI (c) (CC:38) [19:44:29:035]: SOFTWARE RESTRICTION POLICY: C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\SalesUp_6.8.0.2.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (CC:38) [19:44:29:036]: Cloaking enabled.
MSI (c) (CC:38) [19:44:29:036]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (CC:38) [19:44:29:036]: End dialog not enabled
MSI (c) (CC:38) [19:44:29:036]: Original package ==> C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\SalesUp_6.8.0.2.msi
MSI (c) (CC:38) [19:44:29:036]: Package we're running from ==> C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\SalesUp_6.8.0.2.msi
MSI (c) (CC:38) [19:44:29:040]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (CC:38) [19:44:29:040]: APPCOMPAT: looking for appcompat database entry with ProductCode '{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}'.
MSI (c) (CC:38) [19:44:29:040]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (CC:38) [19:44:29:046]: MSCOREE not loaded loading copy from system32
MSI (c) (CC:38) [19:44:29:050]: Machine policy value 'TransformsSecure' is 0
MSI (c) (CC:38) [19:44:29:050]: User policy value 'TransformsAtSource' is 0
MSI (c) (CC:38) [19:44:29:050]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (CC:38) [19:44:29:050]: Machine policy value 'DisablePatch' is 0
MSI (c) (CC:38) [19:44:29:050]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (CC:38) [19:44:29:050]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (CC:38) [19:44:29:050]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (CC:38) [19:44:29:051]: APPCOMPAT: looking for appcompat database entry with ProductCode '{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}'.
MSI (c) (CC:38) [19:44:29:051]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (CC:38) [19:44:29:051]: Transforms are not secure.
MSI (c) (CC:38) [19:44:29:051]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\DELL\AppData\Local\Temp\MSIBBE1.LOG'.
MSI (c) (CC:38) [19:44:29:051]: No Command Line.
MSI (c) (CC:38) [19:44:29:051]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{CC68863B-957A-4D3B-A56B-25402698CB82}'.
MSI (c) (CC:38) [19:44:29:051]: Product Code passed to Engine.Initialize:           '(none)'
MSI (c) (CC:38) [19:44:29:051]: Product Code from property table before transforms: '{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}'
MSI (c) (CC:38) [19:44:29:051]: Product Code from property table after transforms:  '{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}'
MSI (c) (CC:38) [19:44:29:051]: Product not registered: beginning first-time install
MSI (c) (CC:38) [19:44:29:051]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (CC:38) [19:44:29:051]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (CC:38) [19:44:29:051]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (CC:38) [19:44:29:051]: Adding new sources is allowed.
MSI (c) (CC:38) [19:44:29:051]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (CC:38) [19:44:29:051]: Package name extracted from package path: 'test_6.8.0.2.msi'
MSI (c) (CC:38) [19:44:29:052]: Package to be registered: 'test_6.8.0.2.msi'
MSI (c) (CC:38) [19:44:29:052]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (CC:38) [19:44:29:052]: Machine policy value 'DisableMsi' is 0
MSI (c) (CC:38) [19:44:29:052]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (CC:38) [19:44:29:052]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (CC:38) [19:44:29:052]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (CC:38) [19:44:29:052]: Running product '{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}' with elevated privileges: Product is assigned.
MSI (c) (CC:38) [19:44:29:052]: TRANSFORMS property is now:
MSI (c) (CC:38) [19:44:29:052]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\Favorites
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\Documents
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (CC:38) [19:44:29:052]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Local
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\Pictures
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Users\DELL\Desktop
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (CC:38) [19:44:29:053]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (CC:38) [19:44:29:054]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (CC:38) [19:44:29:060]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (CC:38) [19:44:29:061]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (CC:38) [19:44:29:061]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'DELL'.
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\test_6.8.0.2.msi'.
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\test_6.8.0.2.msi'.
MSI (c) (CC:38) [19:44:29:061]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (CC:38) [19:44:29:061]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\'.
MSI (c) (CC:38) [19:44:29:061]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\DELL\AppData\Local\Temp\{B23AE1E3-438B-438C-8A75-D5AFA59CD26E}\'.
MSI (c) (CC:78) [19:44:29:061]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 28/04/43  19:44:29 ===
MSI (c) (CC:38) [19:44:29:066]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (c) (CC:38) [19:44:29:066]: Machine policy value 'DisableRollback' is 0
MSI (c) (CC:38) [19:44:29:066]: User policy value 'DisableRollback' is 0
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (CC:38) [19:44:29:066]: Note: 1: 2203 2: C:\Windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '1000'. Its new value: '601'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '1000'. Its new value: '601'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
MSI (c) (CC:38) [19:44:29:066]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '1'. Its new value: '0'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '601'. Its new value: '600'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '601'. Its new value: '600'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '600'. Its new value: '502'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '600'. Its new value: '502'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '502'. Its new value: '501'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '502'. Its new value: '501'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '501'. Its new value: '500'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '501'. Its new value: '500'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '500'. Its new value: '400'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '500'. Its new value: '400'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '400'. Its new value: '1000'.
MSI (c) (CC:38) [19:44:29:067]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '400'. Its new value: '1000'.
MSI (c) (CC:38) [19:44:29:068]: MsiOpenPackageEx is returning 0
MSI (c) (CC:38) [19:44:29:068]: MsiOpenPackage is returning 0
MSI (c) (CC:38) [19:44:29:068]: Note: 1: 2205 2:  3: MultipleInstancesProps
MSI (c) (CC:38) [19:44:29:068]: Note: 1: 2228 2:  3: MultipleInstancesProps 4: SELECT `PropertyValue` FROM `MultipleInstancesProps`
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_LOGFILELOCATION property. Its value is 'C:\Users\DELL\AppData\Local\Temp\MSIBBE1.LOG'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_MISSING_PREREQS property. Its value is 'Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660|Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40660|Visual C++ Redistributable for Visual Studio 2013 Update 5 x86|AccessDatabaseEngine|MySQL Installer - Community'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_FOUND_PREREQS property. Its value is '.NET Framework 4.6.1'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_BOOTSTRAPPER property. Its value is '1'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH property. Its value is 'E:\مجلد جديد\test_Full.exe'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding SETUPEXEDIR property. Its value is 'E:\مجلد جديد\'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding EXE_CMD_LINE property. Its value is '/exenoupdates   '.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AI_IE_Ver property. Its value is '11'.
MSI (c) (CC:38) [19:44:29:071]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '5'.
MSI (c) (CC:38) [19:44:29:071]: Doing action: AI_DpiContentScale
Action 19:44:29: AI_DpiContentScale.
Action start 19:44:29: AI_DpiContentScale.
MSI (c) (CC:58) [19:44:29:075]: Invoking remote custom action. DLL: C:\Users\DELL\AppData\Local\Temp\MSI108C.tmp, Entrypoint: DpiContentScale
MSI (c) (CC:AC) [19:44:29:077]: Cloaking enabled.
MSI (c) (CC:AC) [19:44:29:077]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (CC:AC) [19:44:29:077]: Connected to service for CA interface.
MSI (c) (CC!34) [19:44:29:578]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '96'.
MSI (c) (CC!34) [19:44:29:578]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '100'.
Action ended 19:44:29: AI_DpiContentScale. Return value 1.
Fatal error: Error 1001.
MSI (c) (CC:38) [19:44:31:348]: Doing action: FatalError
Action 19:44:31: FatalError.
Action start 19:44:31: FatalError.
MSI (c) (CC:64) [19:44:31:353]: Note: 1: 2205 2:  3: AI_ControlEx
MSI (c) (CC:64) [19:44:31:353]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
Action ended 19:44:33: FatalError. Return value 1.
MSI (c) (CC:38) [19:44:33:182]: PROPERTY CHANGE: Deleting AI_BOOTSTRAPPER property. Its current value is '1'.
MSI (c) (CC:38) [19:44:33:182]: Doing action: AI_SHOW_LOG
Action 19:44:33: AI_SHOW_LOG.
Action start 19:44:33: AI_SHOW_LOG.
MSI (c) (CC:78) [19:44:33:628]: Invoking remote custom action. DLL: C:\Users\DELL\AppData\Local\Temp\MSI209B.tmp, Entrypoint: LaunchLogFile
Action ended 19:44:35: AI_SHOW_LOG. Return value 1.
MSI (c) (CC:38) [19:44:35:082]: Doing action: FatalError
Action 19:44:35: FatalError.
Action start 19:44:35: FatalError.
Action ended 19:44:35: FatalError. Return value 2.
MSI (c) (CC:18) [19:44:35:094]: Destroying RemoteAPI object.
MSI (c) (CC:AC) [19:44:35:200]: Custom Action Manager thread ending.
=== Verbose logging stopped: 28/04/43  19:44:35 ===
Is not very clear for me if you tried the solution from my previous reply.
Can you please set the ExtractFilesFirst property to value 1 in "Properties" page (in this way the old files extraction method will be used) like this:
Value: 1
rebuild your project, test again the setup and let me know if that helped?
Otherwise, this error is a generic one and it can have multiple causes. Please have a look on the following article: Source file not found.
