musada1400
Create Dll Serial Validation Using C#
Hi , How To Create Dll Serial Validator in C#?
Re: Create Dll Serial Validation Using C#
If you want to use a DLL developed in .NET make sure you are using Wix > DTF. Here is our article about How to create fully fledged C# custom actions.
Also, you can take a look on our Serial Number Validation DLL article.
musada1400
I Need A dll for Licencing > User Defined Validation
I used Wix Project And I Created A Custom Action like this
        [CustomAction]
        public static ActionResult CustomAction1(Session session)
            session.Log("Begin CustomAction1");
            //var enteredSerialNumber = session["PIDKEY"].ToString();
            //session.Log(enteredSerialNumber);
            return ActionResult.Success;
I Choosed The Dll And I see CustomAction1 But After Run Nothing Happend
Please have a look on the following code example:
namespace SerialValidation
    public class CustomActions
        [CustomAction]
            if (session["PIDKEY"] == "111")
                session["SERIAL_VALIDATION"] = "TRUE";
            else
                session["SERIAL_VALIDATION"] = "FALSE";
You need to set the property and then use that property in your application. For example condition the next dialog to be visible only if the serial validation from the DLL is true:
For more details please have a look on these articles:
1. Developing a DLL for serial number validation - here you also have a Serial Number Validation DLL Sample Project.
2. Package Serial Validation.
