Amin-egn
Upgrade doesn't uninstall previous version and default path
Thu Dec 02, 2021 11:11 am
I built updatable executable and update works well, But when I tested it didn't uninstall previous version and in control panel I got myApp v1.0 and myApp 1.1
In "Upgrades" page I set Order to "Uninstall old version first and then install new version" and check "Customize Advanced Installer upgrade rules"
In addition when I downloaded update I had to find folder, I want to update set it's path to installed folder automatically .
Appreciatively.
Re: Upgrade doesn't uninstall previous version and default path
Thu Dec 02, 2021 3:16 pm
In order for an update to be successful, few rules must be respected:
1. increase the version (which you already did)
2. make sure the ProductCode is different between the two versions
3. make sure the UpgradeCode is the same between the two versions
You can find the ProductCode and UpgradeCode by opening your project --> "Product Details" page --> "Product IDs" tab.
You can also read more about the two in the following article:
Product Identification (ProductCode and UpgradeCode)
