yuvalr
edit ini file
Thu Dec 02, 2021 4:05 pm
when editing ini file the file will be saved different as it was loaded
the sections will be saved according to ABC
for the code- it has no meaning but for the used who is used to see the data in certain order- it is problematic.
there is a way to maintain the file order and just add the needed sections?
Re: edit ini file
Thu Dec 02, 2021 5:13 pm
I am not quite sure I understand your scenario.
If possible, could you please give me some more details (maybe exemplify with some screenshots)?
yuvalr
Re: edit ini file
Wed Dec 08, 2021 4:05 pm
Hi
i am trying to add new section and key to ini file - see attached
example_original.ini
after i modify the ini file , the order inside the ini file is changing - see second file
example.ini
as i wrote- to the SW it is the same but user need to see the same order
example.ini
(689Bytes)Downloaded 82 times
(666Bytes)Downloaded 73 times
Re: edit ini file
Fri Dec 10, 2021 2:50 pm
Thank you for providing these sample INI files.
After having a look over them, I could indeed understand your scenario.
I will update this thread as soon as I'll have a conclusive answer about this behavior.
Re: edit ini file
Fri Dec 10, 2021 3:37 pm
After further investigations and discussions with our dev team, it looks like it is the Windows Installer Engine that writes the .INI file to the disk from the rows in the "IniFile" table.
Unfortunately, we have no control over that.
