nchounlapane
Prerequisite selector version check and controls
Advanced Installer version 16.7
I have a few prerequisites that are under post-install. I'm trying to have the prerequisite selector show the user that the found version of an existing application is older than the required version. Within the attached files, I've included a sample AI project to showcase this. In this example, I have 2 different versions of AdoptOpenJDK that are set to post-install installation. Both Install Conditions are set to Install prerequisite based on conditions with a criteria to check Product Version (identify by Upgrade Code). They both have the same Upgrade Code.
On my local machine, I have the lower version of AdoptOpenJDK installed. During runtime, the latest version of AdoptOpenJDK shows the required version, but the Found version is left blank on my local machine within the prerequisite selector (see image attached). I'm not understanding how AI is checking the current version via Upgrade Code.
Some troubleshooting I've tried:
-Checked Use 64-bit locations when evaluating conditions on a 64-bit machine
-Build on Advanced Installer 18.3
On a separate note, I have a few other questions:
1. Is there a way to disable the checkboxes within the prerequisite selector?
2. If you have an older prerequisite installed (that was originally set as optional install), is there a way to force install on upgrade if there is a newer version from the prerequisite list?
FeatureUpgradeTest.aip
(25.71 KiB) Downloaded 258 times
Re: Prerequisite selector version check and controls
I am not sure I fully understand your scenario here.
Would you expect the "Found" field to display the older version of the "AdoptJDK"?
If that is the case, please note that the "Found" field will only be filled if the respective version is found. This is reflected in the "Action" field, where only the prerequisite whose version was not found will be installed.
I am afraid it is not possible to disable the checkboxes. To achieve this, you might need to develop your own dialog in which you condition the state of the checkbox.
Please note that this should be the default behavior, without the "force" part. If the user will select the prerequisite for installation, then the new version should be installed.
Please let me know if there is anything else I could help you with and I will gladly assist.
nchounlapane
Thank you for your response!
Nick
You are always welcome, Nick!
