Andrey.Burda
Multi instances installation approach
Hello!
I need to implement a bit tricky ability for installation of multiple instances.
I have a "core" installer that installs/configures Web Applications and Windows services. Additional installer will add few more Web Apps to "core" stuff.
Basically, it should copy sources to a specified folder from one of already installed "core" instances. 8-)
The most challengeable part is ability to create new instance of any version dynamically.
I created new project, switched "Generate instances while installation time" and built a couple of installer EXE files of different versions: 1.0.0, 2.0.0, 3.1.1, but with the same name.
First, i installed an instance of v1.0.0 called Treasury, then i run installer twice and selected "install new instance" called "New Instance" and "New Instance 1":
15-12-2021 4-55-43 PM.jpg (72 KiB) Viewed 3491 times
Next, i run the installer v3.1.1. but in this case I have no option to create new instance for this version, only upgrade of existing v1.0.0:
15-12-2021 4-57-57 PM.jpg (52.44 KiB) Viewed 3491 times
I upgraded "New Instance" and then run an installer v2.0.0. Again, i do not see an option for creating new instance for v2.0.0, only uprrade of existing v1.0.0 and v3.1.1:
15-12-2021 4-58-28 PM.jpg (58.1 KiB) Viewed 3491 times
I upgraded "New Instance 1" v1.0.0 to v2.0.0 and once i run the installer of v2.0.0 again, i see an option for adding new instance, but when i choose it - i see a message in dialog saying that "A more recent version of Treasury already installed on this computer".
I noticed that in order to have an ability to create a new instance of let's say v3.1.1, i have to upgrade the "initial" v1.0.0 called "Treasury" to v3.1.1 and the version of new instance should be the most recent among already installed.
But it is not my case. I should be able to create a new instance for v2.0.0 when i already have v1.0.0 and v3.1.1 installed on machine.
Is there any built in functionality to achieve what i want?
I am not an expert in the Advanced Installer, maybe I need some advanced option, custom EXE bootstrapper or whatever.
Thanks in advance.
Re: Multi instances installation approach
Hello Andrey,
Unfortunately, it is not quite possible to achieve this.
This issue was also discussed on the
Multiple Instances doesn't allow upgrading an instance if another instance is upgraded to a higher version
forum thread.
Thank you for your understanding. Please let us know if you have any other questions.
