micropross-ni
How to change the request license dialog from trial (Add hyperlinkto help)
hi,
I read https://www.advancedinstaller.com/user- ... -dlg.html , but I do not found the response to my question,
I would like add a hyperlink in the license dialog to go to a web site to explain how to register
Best regard
Gwendoline
Re: How to change the request license dialog from trial (Add hyperlinkto help)
Hello Gwendoline,
In order to add a hyperlink control to a dialog, please proceed as it follows:
- go to "Dialogs" page
- select your dialog
- on the toolbar, please click on the "Control Toolbox" option
The above should display a little toolbox from which you can use the "Hyperlink" control.
micropross-ni
hi,
I would like changed in the trial dialog, Unfortunately this dialog was not available in the User interface / dialogs
That dialog is displayed from within the trial .DLL code.
In order to modify it, you would need to modify the code.
micropross-ni
hello,
ok, but where is the code of this dll ?
BR
Gwendoline
Hello Gwendoline,
Please disregard my last thread as it seems I may have misunderstood your requirement.
In order to change the request license dialog, please have a look over the following article:
How to change the request licence dialog from trial
Please make sure to make a backup copy of your .AIP file before editing it as it is explained in the article.
