ayap
TFS Build Agent Error: A supported task execution handler was not found.
I had encountered an exception with the Advanced Installer build tasks in TFS all of a sudden.
The exception that I get is : A supported task execution handler was not found. The task does not carry an implementation that is compatible with your current operating system 'Windows'.
This did not happen for the past few days and only showed up all of a sudden. I tried comparing the failed build with a successful one from a few days back and I can see that the installer tool and build tool versions were updated:
1) 1.2.4 -> 1.2.5
2) 2.0.6 -> 2.0.7
I am not sure if that would be related.
I am attaching the screenshot that I had seen in TFS:
Screenshot from TFS build failure
I am also attaching a screenshot from a successful build:
Screenshot from TFS build success
Any help would be appreciated. Thanks.
Re: TFS Build Agent Error: A supported task execution handler was not found.
Hello Alvin and welcome to our forums,
I have replied to your email ticket.
Let's continue the thread there, please.
joao.oliveira
Hi, I have the same problem, can you give me the solution?
Hello Joao and welcome to our forums,
joao.oliveira
We were able to resolve the issue by updating the agent from the build definition.
Agent Version = 2.136.1 updated to version 2.206.0
Thank you for your followup on this, Joao!
Glad to hear everything works as expected now.
