Andrey.Burda
Disable condition on APPDIR property
Hi there,
I am having a problem with mixing up of Combobox and "disable" condition for Next button.
I have a combobox where I want to select a path to target folder, it is mapped to APPDIR property.
For tests I added a label that reflects APPDIR value, by default I set APPDIR="D:/" in "Install Parameters" section:
20-12-2021 5-46-56 PM.jpg (28.37 KiB) Viewed 3820 times
"Next" button on FolderDlg has a condition that if APPDIR = "D:/" - Disable.
20-12-2021 5-46-23 PM.jpg (34.72 KiB) Viewed 3820 times
The idea to is to disable "Next" untill user select any value from ComboBox.
Once I select anything from Combobox, I see that label text get changed, but "Next" button is still disabled:
20-12-2021 5-46-37 PM.jpg (36.86 KiB) Viewed 3820 times
Not sure why Next is not enabled. Seems that dialog is not refreshed or something.
Appreciate for a help.
Re: Disable condition on APPDIR property
Hello Andrey,
In order to achieve that, please proceed as it follows:
1. Select the "Next" button and change it's Enabled attribute to false.
2. In the "Control Conditions" tab add the condition to enable the ComboBox if is not empty.
Attached is a sample project with that scenario. Can you please test it? If you still can't get this working, can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so I can have a look on it?
Your Application.aip
(23.39 KiB) Downloaded 243 times
Andrey.Burda
Hi Liviu,
I was trying the attached example and it works. Also, I modified my project the same way and it works too.
The problem with my solution was that an APPDIR property I mapped to ComboBox cannot be empty. So I created an empty property, mapped it to ComboBox and once user select an item from ComboBox and press Next I call a "Set installer property" to set APPDIR to the path that user selected.
Thanks for a help!
You're welcome, Andrey!
Please let us know if you have any other questions.
