AI_New_User
Which condition to use when delete folder on uninstall?
If I check uninstall, do I also need to type in the condition too?
The right way or redundant? If the latter, then when do I need to type in a condition?
What I'm trying to accomplish is just deleting 2 custom folders on uninstall (not upgrade).
Re: Which condition to use when delete folder on uninstall?
If you want to remove the folder on uninstall, it is enough to schedule the custom action to only execute during "Uninstall" through the option.
There is no need to also input the "REMOVE=ALL" condition.
