NovaES
Install registry key, depending on the operating system
Currently in my application, I am required to use the following code to make the "https" work so that the connections to my server can work.
System.Net.ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12
The problem is that this protocol in Windiws 7 is not activated and must be activated (perhaps in windows server it is necessary to activate it)
As I see in Google, you have to add a registration key, which I have already done.
:arrow: Info protrocol SSL/TLS https://support.microsoft.com/es-es/top ... cjxzdyb000
(I attach a file of the created registry)
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client]
"DisabledByDefault"=dword:00000000
"Enabled"=dword:00000001
My question here is the following, how can I get this key to install for certain operating systems.
NovaES
Re: Install registry key, depending on the operating system
The advanced installer should be able to detect this and install it if it is not there.
You easily achieve this. Please follow these steps:
1. From the "Registry" page create your key structure like this:
tls Win 7.png (37.03 KiB) Viewed 4889 times
2. Now after you created your values, you can either right click on these values --> "Go to Component" option or you can do that for the CurrentControlKey or any other key:
Component registry.png (105.17 KiB) Viewed 4889 times
3. Here on the component properties, in the condition field add the following condition for Windows 7: VersionNT = 601 OR VersionNT64 = 601
You can read more about these conditions in our "How do I install resources based on the Operating System version?" article.
Hope this helps! If you have any other questions, please don't hesitate to contact us.
