portolansanselm
Surface Theme customization of buttons dont work
I have a problem with the redesign of a theme.I wanted to change the "Orange Surface" Theme to our
company colors. To do this, I edited all the files from the path "C:\Program Files(x86)\Caphyon\Advanced Installer 19.0\themes\resources\variations\metroorange".
edited with an editing program and changed the colors. Also it is displayed correctly in the preview:
(See the two buttons are correct)
When I test it now I get the following result:
The buttons as well as the frame is orange again. Sometimes as well the transparent border at the top gets orange too.
Can someone tell me why this is not adopted or how to change the frame as well as the buttons correctly? And of course the window border on
the top too?
Have a nice day and Best Regards!
Stefan Anselm
Re: Surface Theme customization of buttons dont work
Hello Stefan and welcome to our forums,
My colleague Dan has recently wrote an article regarding editing our default themes.
Please have a look over it here:
How-to create new variations for an Advanced Installer theme
Regarding the fact that the button is orange instead of your colour is perhaps because you did not modify the "nextcancelbuttons.png" image.
Also, please make sure you are editing the right resources for your theme. The path to the resource should be something as it follows:
C:\Program Files (x86)\Caphyon\Advanced Installer 19.0\themes\surface\resources\variations\metroorange
not:
C:\Program Files(x86)\Caphyon\Advanced Installer 19.0\themes\resources\variations\metroorange (without the "surface" folder)
(perhaps this is only a typo, so please ignore it if it's not the case for you)
portolansanselm
Hello Catalin,
as you mentioned that was my fault. I replaced the images with the same name and the preview showed me the correct one, so i didnt knew
i have to direct them every single one again. But now it works, thanks a lot, aswell for the article, very helpfull!
Have a nice week,
Stefan
You are always welcome, Stefan!
I am glad everything is working as expected now.
