jansokoly
Has AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION been removed?
According to https://www.advancedinstaller.com/user- ... -odbc.html there should be predefined property called AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION. Is it still the case with AI 19.0 (Enterprise)? Select a property dialog doesn't suggest it at all and if typed in, it's always empty, despite numerous ODBC drivers installed on the machine.
Do I need to enable it somehow somewhere maybe?
Thank you.
Re: Has AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION been removed?
I'm not sure why is empty for you. You can use it like this:
Driver=[\{]ODBC Driver for [AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION][\}];Server=[SERVER_PROP];Uid=[USERNAME_PROP];Pwd=[\{][PASSWORD_PROP][\}];
Can you please have a look over the following forum thread: AdvancedInstaller ODBC Connect: Timeout exceeded
If the above forum thread does not help you, can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
