AI_New_User
Writing DB to another folder?
When use AI to create a sqlite db, by using the "Create database if not exists" option, I get the error below. Is there a way to write the database file to a location that's not in Program Files? (ie. AppLocal) Using "Run as Administrator" option in Install Parameters is not an option for me, unfortunately.
Re: Writing DB to another folder?
I have tried testing this scenario, but unfortunately I was not quite able to reproduce it.
If possible, could you please give me some more details about this? A step-by-step test case which I could follow to reproduce this would really help here.
AI_New_User
I can send a zip of the project, if that would be easier.
Server > Sql Databases
AI_New_User
And when I run the installer.
I tested this, but unfortunately I still can not replicate the described behavior. In my case, the database is created on the disc as expected.
If possible, please forward me a sample project that reproduces this so I can have a look over its settings. Since it's a sample project, you can either attach it here or send it by email at support at advancedinstaller dot com.
AI_New_User
Project attached.
Test Script Install.aip
(20.06 KiB) Downloaded 400 times
Thank you for the provided resources.
I indeed managed to reproduce the issue.
At first, when I manually tried running the query, it gave an error, as the "CREATE TABLE" statement should look like this:
CREATE TABLE IF NOT EXISTS
not like this:
CREATE TABLE [IF NOT EXISTS]
After I fixed that, I managed to manually run the query:
However, it still failed when ran from Advanced Installer.
Unfortunately, I can not say for sure why this is happening. I have forwarded this to our dev team for further investigations and I will update this thread as soon as I will have a conclusive answer.
After further discussions with the development team, the solution for your issue is to use a "Script" instead of a "Query".
The main difference between the two is that a script is ran on the "deferred" stage (therefore elevated), while the query is ran on the "Immediate" stage (therefore not elevated).
