emre
How to set a response buffer limit for a IIS handler?
I am using Advanced Installer 19.0. We are trying to set a response buffer limit for the PHP handler. I use it through FastCGI. On IIS Manager, I can modify this value using the configuration editor as the following image.
I tried to set it using a custom action by running
appcmd.exe set config "WebsiteName" -section:system.webServer/handlers /[name='HandlerName'].responseBufferLimit:"0"
The problem is, when we define a handler using Advanced Installer's Application Mapping window, we can not define a name for the handler, and there is no variable to hold the handler name that defined by Advanced Installer. So it didn't solve the problem. And I am not editing a property, I am editing a collection item property, so I can not use Advanced Installer's custom properties feature. Can you recommend a workaround or solution to set the response buffer limit? Thank you.
Re: How to set a response buffer limit for a IIS handler?
I am not quite sure I fully understand your scenario.
Could you please try to follow the steps presented in the screenshots below and let me know if that helps?
image (1).png (113.57 KiB) Viewed 9607 times
emre
To summarize things, I can not modify the value of the responseBufferLimit when I create a new application mapping on Advanced Installer. It would be awesome if we could modify it using this window:
Screenshot 2022-01-31 010444.png (45.88 KiB) Viewed 9594 times
Hello Emre,
Thank you for your explanation.
I have discussed with our developer and your request is indeed valid.
I will add it on our TODO list of improvements and hopefully it will be available in a future version of Advanced Installer.
Until then, here would be a workaround for your scenario:
Basically, when a new Application Mapping is created, we automatically name it according to the following logic:
CustomMapping-[extension]
In your case, that would be:
CustomMapping-php
If more mappings are created for the same extension, we add numbers to it, so the name is unique, e.g.:
CustomMapping0-php
CustomMapping1-php
etc.
With that being said, the workaround for you would be calling the appcmd.exe, as it follows:
appcmd.exe set config "MyPhpTrial" -section:system.webServer/handlers /[name='CustomMapping-php'].responseBufferLimit:"1234"
emre
Sounds great, this approach will solve my problem. Thank you for the feedback and your time!
You are always welcome!
