Andrey.Burda
Dynamic property name for AI_GetMsiProperty
Tue Jan 25, 2022 8:58 am
I want to pass in a dynamic value for AI_GetMsiProperty inside the Power Shell inline script (execution time is set to Immediately) but it does not work.
General aim is to get a folder path inside the loop by calculating a property name from "Files and Folders".
For instance I haver a folder "TestApi" and "TestApi1", the identifiers generated by AI are: TestApi_Dir and TestApi1_Dir.
I have a comma separated string with a list of folder names in custom property - MIGRATION_SERVICES. It value is "TestApi,TestApi1".
In Power Shell script I do the following:
$migrationServices = AI_GetMsiProperty MIGRATION_SERVICES
$migrationServices.Split(",") | ForEach-Object {
  $dirName = $_ + "_Dir"
  $Path = AI_GetMsiProperty $dirName
  if ($Path -ne '') {
exit 0
$dirName is set to: TestApi_Dir and TestApi1_Dir.
The problem is that $Path is always empty, but this line will return a correct path: $Path = AI_GetMsiProperty TestApi_Dir
I wonder what I missed?
Andrey
Re: Dynamic property name for AI_GetMsiProperty
Wed Jan 26, 2022 5:00 pm
Hello Andrey,
Please note that the AI_GetMsiProperty cmdlet cand only be used with installer properties.
In your case, $dirName is a variable, not an installer property.
Andrey.Burda
Thu Jan 27, 2022 3:44 pm
Thanks for the reply.
Is there any way to receive AI properties in Powershell script a bit more dynamically, for instance by string name ?
Andrey
Mon Jan 31, 2022 9:42 am
Hello Andrey,
You can first retrieve the property into a variable and then pass the value to another variable, something like this:
$var = AI_GetMsiProperty SOME_PROPERTY
$var2 = $var
Andrey.Burda
Tue Feb 01, 2022 11:21 am
Unfortunately, I have a string name of the property and I want to get it value that set in AI Properties.
Looks like PowerShell inline script is not my option at all.
Andrey
Tue Feb 01, 2022 2:48 pm
Hello Andrey,
Perhaps I am misunderstanding something here.
So, you have the name of the property stored in a variable, e.g.:
$var = "MY_PROP"
and then you want to retrieve the value of "MY_PROP" into another variable, e.g.:
$var2 = AI_GetMsiProperty $var
where $var would eventually be replaced by "MY_PROP" and then $var2 would have the value of "MY_PROP"?
Is this what you are trying to achieve? If this is the case, then I'm afraid this might not be possible with the AI_GetMsiProperty cmdlet.
However, there might be another way, through the Get-Property cmdlet (which we recently added), e.g.:
$var = "MY_PROP"
$var2 = Get-Property -name $var
Andrey.Burda
Tue Feb 01, 2022 3:34 pm
Seems that "Get-Property cmdlet" is what I need.
Thanks a lot!
Andrey
Tue Feb 01, 2022 3:50 pm
You are always welcome, Andrey!
Glad I could help.
