jmoleary
How can I make this custom driver install step work?
I want my installer to run a simple Windows command that uses an .INF file to install a driver. I want to make AI (Professional) do the equivalent of this Windows command line command
pnputil -i -a ximeausbx64.inf
This command works just fine when I personally run it from the Windows command line as an Admin. And my installer requires Admin privileges. But I cannot figure out how to make AI do this for me.
I added the folder with the .INF and all needed files to the APPDIR as a subfolder (called "XimeaUsbDrivers"). Then I tried to add some Custom Actions.
First I rejected using Launch File and Launch Installed File because they seem to require an EXE, MSI or some other type but not a Windows batch file
Next I rejected Execute inline script code only allows for VBS or Javascript
But the Run PowerShell inline script step seemed promising. I googled around and found what looks to be a powershell command that will do it
Get-ChildItem "C:\mydrivers\" -Recurse -Filter "*.inf" |
ForEach-Object { PNPUtil.exe /add-driver $_.FullName /install }
So I just need to change
C:\mydrivers\
to be... whatever the installed path of XimeaUsbDrivers is.
And I tried to do that. Tried to give the script an argument of [APPDIR]\XimeaUsbDrivers. Tried to make the script take it as an argument and pass it to the command. I cannot get it right. The installer runs but this step never seems to happen. The drivers do not get installed. The installer log file tells me nothing.
Am I doing this totally wrong? Can someone point me in the right direction?
-Joe
Re: How can I make this custom driver install step work?
Hi Joe,
In order to achieve this, you have multiple options:
1. You can directly launch a CMD or .BAT file using the "Launch file" custom action. You can pass the folder parameter and even the file path to your script:
bat file.png (55.22 KiB) Viewed 10779 times
Please have a look on our How to launch a CMD or BAT file article for more details.
2. You can pass the folder/file parameter to your PowerShell script like this:
PS parameter.png (156.6 KiB) Viewed 10779 times
More details on the Run Inline PowerShell Script article - "Getting a property value into a script (for deferred custom actions)" section.
Please note that when you type "[" in the parameter field multiple options appear which allow you to select a file or folder directly.
You can also find your folder identifier by right clicking on it and select "Properties":
folder identifier.png (113.58 KiB) Viewed 10779 times
jmoleary
Thank you. This was an extremely helpful reply. I managed to make it work
You're welcome!
