e.klimov
Installer automatically deletes another app
Hello there,
I'm using advanced installer 12.8 and getting this problem:
I had one application and installer for it and everything was okay, then i wrote second similar application copied installer of the first application and changed all settings like product name and all another, even digital signature is different. Then if i install first application and then second application everything works fine. But if i install second application and then first application installer of first application before installation deletes second application. These apps have different install directories, different names, versions. I did not find any similar settings. I think i can create new installer from scratch for the second application, but then users who already have it will have some problems with updating, i guess.
So can you help me, Where can be the problem?
Re: Installer automatically deletes another app
I'm not quite sure why that happens.
In order for us to further investigate this, can you please send us the following resources:
1. the .AIP (setup project) file for the first version;
2. the .AIP (setup project) file for the second version;
3. an installation log when the described behavior occurs;
by e-mail to support at advancedinstaller dot com?
Also, if I understand correctly, you copied the .aip file from the first version and changed it's settings? If that is the case, please note that using the "copy-paste" method when you want to duplicate a project may lead to many problems. The "Save as Template" option is very useful when you already created a project with many configurations and want to duplicate it for creating another similar project. Please find more information on our Using the "Save as template" option article.
