Bobbloggs89
Error during install.
I'm trying to create a package by incorporating a batch file into it but getting an issue as per attached screenshot.
The application is readily available from https://github.com/forcedotcom/dataloader.
I have attached my project, the batch file and the screenshot.
Any guidance, would be awesome.
Thank you.
Screenshot 2022-02-07 161502.jpg (169.95 KiB) Viewed 11038 times
install.txt
(5.81 KiB) Downloaded 400 times
Dataloader.aip
(81.55 KiB) Downloaded 392 times
Re: Error during install.
Hello Bob and welcome to our forums,
From what I can see, you are adding the .BAT file in your project and then launch it through a "Launch File" custom action.
I am assuming that what is seen in the screenshot is the output of the .BAT file (please correct me if I'm wrong).
If that is the case, the error is related to the batch file and not your main project. By the look of it, I would assume that is a permissions issue.
Could you please go to "Custom Actions" page --> select the "Launch File" custom action --> check the "Run as administrator" option and let me know if that helps?
Bobbloggs89
Thank you , good to be here. :)
Tried your suggestion unfortunately it didn't work.
Your correct the output from my previous screenshot is from the batch file.
Attached a screenshot of my Custom Actions window.
Got the same error as per my initial screenshot.
Hope it helps.
Screenshot 2022-02-10 170145.png (63.07 KiB) Viewed 11020 times
Hello Bob,
It looks like this is not a permission issue, although the encountered message would suggest so.
If possible, could you please forward me a download link for the setup package by email at support at advancedinstaller dot com (the github link you provided does not seem to have the setup MSI/EXE under "Releases", or perhaps I somehow missed it)?
Additionally, does the creation of the shortcut work outside of Advanced Installer (e.g. if you simply launch your .BAT file from command line)?
Bobbloggs89
Apologies for the delay, just got back from hols.
Just sent a response to the support e-mail address as per above.
Thank you.
Hello Bob,
No worries about the reply. I hope you enjoyed your days off! :)
Thank you for the provided files!
Regarding this issue, I indeed managed to reproduce quite the same behavior, but it looks like the shortcut is still created on my machine.
The "Start Menu" shortcut is also created as expected.
Now, this error, from what I know, is a System error (0x3).
On your machine, is the shortcut not created at all?
Bobbloggs89
Any time off work is good :D
Thank you for continuing to look into this.
Apologies should of clarified, issue seems to occur when a user (without admin rights) tries to install the software - is there any way to get around this?
Thank you.
Hello Bob,
That's for sure! :)
Are you positive that this is the case? I am asking this because, from what I can see in your project, the "Installation Type" is set to "Per-machine only (fails if user is not administrator)".
What this means is basically when the user will try to install it, the installation location is a per-machine one and therefore admin rights will be required. If the user is indeed not an administrator, then the UAC should prompt the user to enter the credentials (username and password) of an administrator user.
Bobbloggs89
Definitely creates no icon nor brings up any prompt.
Is there something I need to change so that any user can install without admin prompt or admin rights?
Thank you.
Hello Bob,
To avoid the UAC prompt, some things are required:
- first of all, you need to set the "Installation Type" to "Per-user only" in the "Install Parameters" page
The above will ensure that your files from "Files and Folders" page --> "Application folder" will be installed in a per-user location (e.g. %appdata%)
- besides that, you need to make sure that no other files are installed in a per-machine location (such as the Program Files & Program Files (x86) folders)
- the same as above goes for registry entries as well (i.e. your setup should not try to write in a per-machine location such as the HKEY_LOCAL_MACHINE)
- additionally, your custom actions should also not require administrator privileges. For instance, if a shortcut is created (like in your case), you need to make sure the shortcut is created for the user that performs the installation, not on the Public Desktop (available for all users)
This should pretty much be all.
Hope it helps!
Bobbloggs89
Thanks for this Catalin.
Can you please advise on how I use Advanced Installer to set the app to:
Make sure the shortcut is created for the user that performs the installation, not on the Public Desktop (available for all users)
You are always welcome!
Regarding the above, this is achieved by:
- setting the installation type to "Per-user only" in "Install Parameters" page
- creating the shortcut on the Desktop, as usual
After installation, you can check this by opening the following location:
C:\Users\Catalin\Desktop
and seeing if the shortcut is there.
The per-machine location for the above would be:
C:\Users\Public\Desktop
