Thom-M
Install SQL Server without asking for Extracted-Files directory
I'm looking for an installation option to install the SQL Server 2014. The Setup shouldn't be silent, but the user shouldn't be asked for the Extracted-Files directory.
If I include the Parameter "/u", the setup will *correctly* NOT ASK for Extracted-Files directory, but after the copy-process I got finally this error-message:
However, if I don't include the "/u" parameter, the setup will always ask for Extracted-Files directory. But I don't want to ask the user for this directory:
This is my Install Command Line (incl. /u)
/IACCEPTSQLSERVERLICENSETERMS /ACTION=Install /FEATURES=SQLEngine /INSTANCENAME=SQLEXPRESS /UpdateEnabled=False /x:%TEMP%\SQLInst\ /u
This is my Install Command Line (without /u)
So how can i start the SQL Server installation process (incl. Microsoft SQL Server Installation-Dialog), without asking for the Extracted-Files directory?
thank you, TM
Re: Install SQL Server without asking for Extracted-Files directory
Hello Thom and welcome to our forums,
If possible, could you please try the command line from the following article (/x <path>):
Install SQL Server 2017 Silently/with BasicUI
and let me know if that helps?
Thom-M
as you can see, I already use this command-param...
Attached I'll send you the complete AIP-project file. :idea:
SQLTestinst.aip
(20.33 KiB) Downloaded 493 times
Hello Thom,
I am sorry, I did not quite see the parameter in your first post.
I believe this might be the default behavior for SQL Server Express 2014. From what I can see, the extract location is correctly set, however the dialog is still displayed to the user.
To avoid this, perhaps we might need to install it silently using either the "/q" or the "/qs" parameter.
This might simply be a limitation of SQL Server Express 2014, as explained in the following thread from Microsoft's forums:
SQL Server 2014 Express extract file parameter?
Regarding the error, this might happen due to the fact that your prerequisite is not actually installed (the "Continue with the main installation even if the prerequisite isn't installed" option is unchecked in "Prerequisites" page) due to a wrong command line.
Basically, the command line that you are using does not work. It only extracts the SETUP.EXE, but doesn't install it.
You can test this by going to the location where your prerequisite was downloaded and launch it with the same command line:
/x:%TEMP%\SQLInst\ /u /IACCEPTSQLSERVERLICENSETERMS /ACTION=Install /FEATURES=SQLEngine /INSTANCENAME=SQLEXPRESS /UpdateEnabled=False
You will see that the setup is only extracted but never installed.
With that being said, please make sure that the command line you are using works outside of Advanced Installer first.
Thom-M
Thank you,
but what is the correct way to start the SQL Server Setup without asking any path?
I just want the normal "Microsoft installation dialog" to appear (not silent, so that the user can make various settings!).
Or is this not possible?
Hello Thom,
Whether this is possible or not, I can not really say.
As far as I tested this, it looked like it may not be possible, but I can not say for sure.
You can try to further investigate this and if you find a command line that works outside of Advanced Installer (e.g. from command prompt), then it should work from within Advanced Installer as well.
jermitts
The syntax is /x<SPACE>[path to folder] not /x<colon>[path to folder]
setup /x foldername works...
Jeremy
Hello Jeremy and welcome to our forums,
Thank you for sharing your solution with us.
