prakash
How to activate older versions?
I have an advanced installer enterprise license. And I have to create an installation package for windows xp SP2 computers. So I downloaded and installed the 12.5.1 version. A licensed 19.1 version was already installed on that workstation.
When I open the 12.5.1 and try to create a project, I got attached error. Also no option was provided in the interface to apply the license key.
Is there any special way to be followed to apply the license?
Prakash
Re: How to activate older versions?
Hi Prakash,
Can you register the 12.5.1 version of Advanced Installer with your license key as detailed in the "Registering Advanced Installer" article and see if this helps?
prakash
Hi Eusebiu,
I tried with that. It did not worked.
I choose online activation and provided the key. It shows "Thank you for registering advanced installer."
But when I go to the about page, It still shows I am running on trail.
Hello Prakash,
That is quite strange, indeed.
In fact, I have tried testing the exact same scenario on my machine. After installing the older version, it was already registered, I did not have to re-register it.
Could you please try to install the 12.5.1 version of Advanced Installer on another machine (e.g. a Virtual Machine) and retry registering it there? If that works, you can save the snapshot of the VM and start developing your project there.
