thank you for the answer and the hint with the tables. I think I understand it now a bit better how Advanced Installer search works and can rephrase the question a bit more precise.
Lets suppose I have a simple PowerShell Inline Script e.g.
# Block for declaring the script parameters.
Param()
# Your code goes here.
$somevariable = 42
when I try to find
$somevariable the result does not appear, even if when I check all tables in the
Look in combobox for the
Find All dialog.
When I open the
Table Editor (or alternatively the msi file in Microsoft's Orca tool, the variable exists in the
CustomAction table. So theoretically the search should have found the
$somevariable.
But when I search for parts of the base64 encoded string (related to the recent post about the diff) I get a hit
- FindCustomAction_Base64.png (354.31 KiB) Viewed 15531 times
Probable not very helpful. May be it is a bug.
I'm using version 19.1
best regards,
Stefan
