AquaComm
VS2019 AI Extension - Unable to save AI Path
I have uninstalled and re-installed the vix installer for the AI Extension to VS2019 and note that the Path is not automatically inserted when using vix.
I then tried to manually install the path however it is impossible for me to save the path. Moving the mouse to a different input box or clicking on Save clears the path entered before the window closes.
mp4 is attached.
AI v19.2. Licenced.
Path.zip
Contains MP4
(657.14 KiB) Downloaded 201 times
AquaComm
Re: VS2019 AI Extension - Unable to save AI Path
Removing the inverted comma's has allowed me to save the path.
When I try to open the .aip file, I am told that IA needs to be downloaded and installed. I chose to Repair. Tried to open the api file again and told I had to Install AI !!!
Ran Modify this time. Shut down VS2019, reopened VS2019 project and the aip file now opens in VS2019.
Another normal day at the office :roll:
Yes, by default you don't need to include the path in quotes in Visual Studio. That is the normal behavior of Visual Studio.
The same thing happens for the Project location and any other path option:
default location.png (43.59 KiB) Viewed 2485 times
I'm glad to hear that everything is working as expected now.
Please let us know if you have any other questions.
