Hello Stefan,
Thank you for the explanation!
Now I understand your scenario.
First of all, let's address this:
if I create a new setup with version 19.1. the placeholder feature does not work at all, therefore I describe the problem in our current setup.
Most likely, this does not work because you have the
"Enhanced User Interface" option disabled in your new setup. To enable it, please go to
"Themes" page -->
"Settings" tab -->
"Use Enhanced User Interface" set to
"Always".
Now, regarding this:
The default value is mongodb://, when I remove the default text and move the focus to a different control, the placeholder text is shown and formatted cursive black.
and this:
Beside the problem that the feature does not work with a newly created setup. It would be great if I could specify the colour of the font. As an example see the search box on the top of this community forum page. There the word Search is also grey.
You can achieve what you want by setting the
"Text Style" for your control. In your first screenshot, under
"Text Style", there is a
"Text Style" field which will let you set it.
The text styles can be found in the
"Themes" page -->
"Text Styles" tab. There, you have some default ones, but you can also create new ones.
- DlgFontBold.png (112.22 KiB) Viewed 4104 times
