Veverke
I need Product Details Version field to hold a 3-digit version number, instead of 4
product details screenshot
Hi there,
we are now moving from 4-digits versions to semantic versioning (3 digits).
As far as we understand, Product Details screen - Product Details group box's Version field takes the version info from .net's FileVersion (https://docs.microsoft.com/en-us/dotnet ... ew=net-6.0)
This means that the MSI we generate using Advanced Installer is always released with a 4 digit version number.
What could be done here so we can have the MSI versioning matching our new standard of 3 digits ? .NET 's FileVersion always uses 4.
Re: I need Product Details Version field to hold a 3-digit version number, instead of 4
If you want to synchronize the Product Version of your setup with the Product Version from your .EXE, then I'm afraid it is not possible to have only the first 3 fields, since the EXE uses 4.
The only solution would be manually inputing it.
If you have any other questions, please let me know and I will gladly assist.
