steven.wood
AI 19.2 + 19.2 hanging
I am attempting to open the attached AIP project file in AI 19.1.
AI hangs and I have to shut it via the task manager.
I updated to 19.2, and the same problem occurs.
If I start AI without loading this project it works fine.
Other projects work fine.[/list]
What is it about this project file?
VSC QC1+ x64.aip
(198.31 KiB) Downloaded 141 times
Re: AI 19.2 + 19.2 hanging
Hello Steven,
I have tried opening the .AIP File using version 19.2 of Advanced Installer and everything worked as expected - the program does not hang at all.
Are you constantly able to replicate this behavior? Also, have you tried testing this on a clean machine (e.g. a Virtual Machine)? If so, does the issue still reproduce?
