AI_New_User
Azure DevOps: Error calling MSI API: 161 Method: MsiRecordSetStream Table: _Streams.
When running AI 18.9 on Azure DevOps, I get this error message:
Checking builds status
Build required.
[ AppSetup ]
Building package: D:\a\1\a\MSI\AppSetup-20220310.5.msi
Prepare build
Detecting MSI incompatible resources
Preparing files
Creating CAB file(s)
Creating MSI database
Inserting CAB file(s) into MSI
##[error]Failed to execute Advanced Installer task. Error: SetPackageName "AppSetup-20220310.5.msi" -buildname "AppSetup"
SetOutputLocation -path "D:\a\1\a\MSI" -buildname "AppSetup"
Build -buildslist "AppSetup"
Build required.
[ AppSetup ]
Prepare build
Preparing files
Finishing: Create Installer msi
If I run this locally on my desktop, I don't get this error and the MSI is built and created.
Re: Azure DevOps: Error calling MSI API: 161 Method: MsiRecordSetStream Table: _Streams.
Could you please double check to make sure you are building the same .AIP file on DevOps and locally on your machine?
This is quite strange, as there shouldn't be any difference between building in Azure and on your local machine.
If possible, please go to "Azure" --> "Repos" --> "Files" --> download your .AIP file and send it to me by email at support at advancedinstaller dot com together with the command line you are using so I can have a look over it.
Unfortunately, it looks like the email did not get in our inbox.
Could you please try to send it again and then let me know so I can check?
Thank you for providing the AIP file.
I have had a look over it and everything seems to be configured just fine.
Are you able to replicate this behavior in a sample project (i.e. a newly created project)? If so, could you please forward me that project so I can run some tests with it on my end?
I have tried running some tests using a sample AIP file on my end, but I was not able to reproduce that issue.
