hms
Another version of this product is already installed
Will you please tell me what could be causing this? Why isn't uninstalling the old version? Why isn't the version number automatically updating?
Also, I received the same message when Use original installation path when upgrading was checked.
Will the Professional version allow me to retrieve the version of an EXE file by using Advanced Installer’s GUI? If so, where is step 2 now located?
1) Go to the Install Parameter page.
2) Add a new property.
3) From the “Edit Property” window, set the property's value to be automatically retrieved from the executable file.
Thank you
hms
Re: Another version of this product is already installed
Never mind, I need stronger glasses. It was literally right there on the Product Details Page.
Thank you
I'm glad to hear that you found the solution,.
If you have any other questions, please don’t hesitate to contact us.
