Andrey.Burda
Install few different Products built by AI
Hi there,
I am having a problem while installing two diferent Products into the same APPDIR.
I have two AI projects for two different installers. I want them being installed into the same APPDIR and have same or different version.
Let's say first installer installs Service1 to APPDIR and the second one - Service2.
On the below screen it is Test Product of version 1.0.0 and Test1 Product of the 1.0.0 version:
17-03-2022 12-42-18 PM.jpg (14.13 KiB) Viewed 2194 times
17-03-2022 12-43-55 PM.jpg (15.67 KiB) Viewed 2194 times
The problem is that once I run first installer ( Service1 installed as well) and then I run second installer of version 1.1.0 - it removes Service1 (basically Test Product).
Seems that the system treats Test1 Product installer as an upgrade to Test Product installer.
I was thinking that once I set a different ProductNames it should say the system that installers are different too and installer separately from each other.
I want to totally distinguish these two installers.
Maybe there are some settings I missed?
Appreciate any help.
Andrey
Andrey.Burda
Re: Install few different Products built by AI
Seems that I solved the problem by re-generating Product Update code because the second AI project was based on the first one and the Update Product code was the same.
Hello Andrey,
I am glad you sorted this out on your end.
If there is anything else I could help you with, please let me know.
