I am having trouble figuring out how to digitally sign Advanced Installer's updater.exe file.
I have an Azure pipeline that signs all dlls and exe files that result from running dotnet publish.
Problem is, since AI's updater.exe is not part the code base, rather an external AI file, it obviously does not show in dotnet publish results.
1. After installing an MSI package created with Advanced Installer - where does the updater.exe file - we see residing side by side with all the dlls and exes generated by dotnet publish - where does AI take it from to deploy it in the installation folder ?
2. I need to know this because my product is digitally signed using azure signtool - by issuing the command on each and every file dotnet publish generated (which are ultimately deployed
into the MSI's client installation folder). But since I do not know where `updater.exe` is taken from I can't sign it using the same procedure as for all other files. I am not that familiar with AI, I believe it must provide its own customized mechanism for doing that, but feels to me that simply knowing where the updater.exe deployed in the installation folder is taken from would be enough - I would use azure signtool to sign it just as well - and I will be sure all files are signed the same way, same certificate version, etc.
Is it safe to assume that its location is defined on screen Resources -> Files And Folders -> right click on updater.exe -> Properties , and that it is copied at MSI unpack time into the installation folder?
