Hello Max,
Unfortunately, Advanced Installer does not have support for this (to Set Logon As A Service right to user).
However, this is already on our TODO list of improvements. I have increased its priority and hopefully it will be implemented in a future version of Advanced Installer.
As soon as this improvement will be available we will notify you on this forum thread.
Also, as a solution, you can achieve this using a custom action script (PoweShell, VBScript).
For more information, please refer to the below article:
Set Logon As A Service right to User by Powershell, C#, CMD and VBScript
I've tested the VBScript and is working as expected. The
"Execute inline script code" custom action needs to be added after
"Add Resources" action group with the
"When the system is being modified (deferred)" and
"Run under the LocaSystem account with full privileges (no impersonation)" options checked.
- Sample demo.png (251.05 KiB) Viewed 2083 times
Hope that helps!
