vmfrt
Failed to make a scheduled task with GUI hidden
If we check Run whether user is logged on or not in Windows OS interface then task's GUI is successfully hidden but this option is not available in advance installer
As in Windows 10's Interface
While no option in Advance Installer
Re: Failed to make a scheduled task with GUI hidden
Please note that this improvement has already been implemented in our latest version of Advanced Installer.
vmfrt
I think I am failed to described my problem.
My goal is to hide console interface from user and run it as background process. So it can be achieved by checking Option with Radio button "Run whether user is logged on or not" (available in windows OS GUI) but it is missing in Advance Installer. Is it available in latest version of Advance Installer ?
Yes, that is available in the latest version of Advanced Installer.
As a followup to my last thread, I somehow confused the two settings.
It looks like we currently do not have support for the "Run whether user is logged on or not" option.
I will add this on our TODO list of improvements and hopefully it will be added in a future version of Advanced Installer.
vmfrt
Catalin wrote: ↑Fri Mar 25, 2022 9:54 am Hello,
Thanks for your reply....
Is there any other option that we can select this option via custom actions ? or any other method ?
You're welcome!
Yes, that can for sure be achieved through a custom action - e.g. a PowerShell script, VBScript, C#, etc.
You could only create a custom action that modifies the current Scheduled Task created by your setup, that basically only checks that option you require.
The custom action should be scheduled after the "Add resources" action group with its "Execution Time" set to "When the system is being modified (deferred)".
Additionally, you might need to check the "Run under the LocalSystem account (with no impersonation)" option, so your custom action runs elevated.
After further discussing this with our dev team, it looks like you can achieve this by unchecking the "Run only if this user is logged on" option and then providing a username and password for the scheduled task.
vmfrt
Catalin wrote: ↑Tue Jun 21, 2022 3:51 pm Hello,
Thanks for Reply. But I want to use this setting for production. I dont know user name and passwords of my customers. So, please guide how to use it for production?
A way of doing this would be to create a custom dialog where you ask the user to input the required data, in our case the username and password and then use those for the scheduled task.
