Veverke
Advance installer gets stuck during the signing process with azure pipeline
We are trying to build advanced installer AIP file using azure pipeline classic.
The “Use from Azure Key Vault” option is turned on,
And the build is called with ai execute file:
;aic
SetAzureKeyVaultSecret <our_secret>
Build
When running this build on the self-hosted build server locally – it works fine and the build step succeeds and files are sign,
When running it with azure pipeline – the build gets stuck in the build step with no error log.
The pipeline server is windows self-hosted.
Advanced installer version: 18.3
Thanks.
Re: Advance installer gets stuck during the signing process with azure pipeline
Unfortuantely, I can not say for sure why this is happening.
Did you change anything before this happening? I am asking because you have another thread going on here on our forums where you described that the Updater.exe tool was not signed after building in Azure DevOps, meaning that the build actually worked at some point.
If possible, could you please provide some screenshots of the build agent on your end so I can have a better view on this? Of course, if there is some sensitive information, you can leave it out.
