mpande
Scheduled Task
Hi! Is it possible to set the Install Condition in such a way that a scheduled task is not recreated during an upgrade?
mpande
Re: Scheduled Task
I should be clear, our goal is to have a scheduled task created during the original install, and then have that scheduled task remain in place unmodified even if upgrades take place.
Re: Scheduled Task
In order to achieve that you can condition the installation of the related schedule task through the "Install Condition" field in the "Task" tab of the Task properties dialog. Just add the "OLDPRODUCTS" condition in that field.
task condition.png (69.11 KiB) Viewed 2575 times
You can take a look on the Edit Condition Dialog article which may be useful to you.
