Zsolt Kollarits
Unexpcted "Package was created with a trial version.." warning dialog appears
Hi Advanced Installer Support Team,
Please take a look at the attached screenshot, could you please tell us why we get a warning message of:
"This package was created with a trial version of Advanced Installer..."
We just downloaded your latest - stable? - version from your webpage, the version 19.3, and we have a license till 2024.
Zsolt Kollarits
Re: Unexpcted "Package was created with a trial version.." warning dialog appears
Hello Zsolt,
Indeed, as you mentioned, your Maintenance Plan is active until 2024.
However, from what I can see in our database, you guys recently extended the Maintenance Plan (February 21st).
What I'm assuming happened is that you did not re-register Advanced Installer on your machine and therefore the Maintenance Plan did not get updated.
Please re-register Advanced Installer as per the following article and everything should be working just as expected:
Registering Advanced Installer
Zsolt Kollarits
Dear Catalin,
Thank you for your tip, I re-registered the tool and the warning dialog is gone now :)
Zsolt
You are always welcome, Zsolt!
Glad everything works as expected now.
