WPA
"Microsoft Store" app gets stuck at "Starting Download" while installing "MSI" apps!
Can anybody here confirm if "Microsoft Store" app gets stuck at "Starting Download" while installing "MSI" apps?
Example of "MSI" apps available in the Microsoft Store:
PdfClerk (msi): https://apps.microsoft.com/store/detail/XPDNZBWB3272RL
Keyboard and Mouse Locker: https://apps.microsoft.com/store/detail/XP89DDJX33KGVG
The apps mentioned above should be silently installed with "MSI" installer from "Microsoft Store" app!
Note that, "Microsoft Store" app may need\must be updated in order to be able to find and install "MSI" apps!
We already wasted a lot amount of time trying creating MSIX\APPX packages for our portable tools, only to find out that, like in most traditional Win32 apps cases, they are severely incompatible with MSIX\APPX system!
We want now to create "MSI" packages for our portable tools, but it seems that "Microsoft Store" app can neither download "MSI" apps nor install them!
WPA
Re: "Microsoft Store" app gets stuck at "Starting Download" while installing "MSI" apps!
It turned out that "VirtualBox" virtual machine was the culprit! (and by the way, it was not mentioned that Windows 10 was being run in "VirtualBox" virtual machine, apologies for that.)
The problem is that "VirtualBox" was using only 1 CPU to run Windows 10, and Windows 10 requires at least 2 CPUs to run properly.
Changed CPUs from 1 to 4, and voila, problem fixed!
VirtualBox - Change number of CPUs to be used.png (60.84 KiB) Viewed 2421 times
Hello!
I'm glad you found the solution. Thank you for your follow-up on this and for sharing it with us!
I am sure this will be of help for other users facing a similar scenario.
