maxschaf
Azure Key Vault signing using latest certificate
using Azure Key Vault for signing requires to set certificate version id in project configuration. It would be a great feature to always use the latest version of a certificate, then renewing the certificate is easier because Ai project file does not need to be adapted.
Screenshot 2022-04-09 203602.png (5.19 KiB) Viewed 29734 times
Re: Azure Key Vault signing using latest certificate
Thank you for your suggestion!
I have added this on our TODO list of improvements and hopefully this will be implemented in a future version of Advanced Installer.
After further discussions with our dev team, it looks like what you want to achieve should already be supported.
In order to always sign with the latest version of your certificate, you should leave the "Certificate Version" field empty.
Return to “Feature Requests”
