RambosRide
Uninstall Slow as in 76mb over 15-20 min.
I had 2gb installed that uninstalled in <2 min...
Created a smaller footprint project for testing at 76mb installed.
Now uninstall takes 15-20 min?
I'm evaluating the software for purchase and really need to solve this issue.
I'm using AI 19.3
Thanks!
Re: Uninstall Slow as in 76mb over 15-20 min.
Hello Dan,
In order for us to further investigate this, could you please forward me the following resources:
- a copy of your .AIP file
- a download link for the setup
by email at support at advancedinstaller dot com?
RambosRide
Email Sent!
Hello Dan,
As a short decription for others facing a similar scenario, the problem was generated by a large .INI file added in the Windows Installer format.
Please note that the "Windows Installer format" is only used if you want to update the INI file at install time with the user's input.
To overcome this behavior, you can simply remove the INI file from your project and re-add it, this time as a regular file.
Hope this helps! Please let us know if you have any other questions.
