ogelfond
Weird rendering issues with UI
I'm seeing some strange rendering issues:
Using AI v19.3, Graphite theme, Enhanced User Interface enabled Always.
During design and building using Test Installation UI the dialogs look correct (see attached 1 & 2)
But when building and running the generated exe the controls in these two dialogs look completely messed up. (see attached #3)
I will appreciate your help in resolving this. Thanks!
Re: Weird rendering issues with UI
I'm not sure why that happens.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
ogelfond
Thank you for your quick response. I restarted the AI editor and was able to see the issue in the Dialog design. No further help is needed, thanks!
You're welcome!
I'm glad you got this working! :)
Please let us know if you have any other questions.
