sonda
Find
When the find function is used only XML is searched but it will be nice, also to search inline scripts (scripts included in the project) (PowerShell, VBScript javascript). If you want to find where your property is used now you need manually check all scripts. Just suggestion... :)
Re: Find
Thank you for your suggestion! :)
We already have this on our TODO list of improvements and hopefully it will be added in a future version of Advanced Installer.
I will update this thread as soon as I will have more information on this.
Return to “Feature Requests”
