mli04
After uninstalling the software, a folder remains in the application directory
Hi ,
When my software is uninstalled, a folder like the following will remain in the application directory:
0ac3967-03ab-ae7-a198-b552
This folder also contains an empty Config folder.
For more information about application directory operation settings, see Attachment Files.
Use Advanced Installer V18.8.1.
Andrew
Re: After uninstalling the software, a folder remains in the application directory
Hello Andrew,
I'm not sure why this is happening.
In order for us to further investigate this, can you please forward by email to support at advancedinstaller dot com the following resources:
1. the .AIP project file
2. a download link for your setup package so we can test it
3. an uninstallation log.
mli04
Sorry, I can only provide uninstall logs due to company confidentiality restrictions.
Also, I found that the application folder was deleted during the uninstall process.
But finally 0ac3967-03ab-ae7-a198-b552\Config folder was restored.
uninstall.log
(680.99 KiB) Downloaded 414 times
mli04
I updated this uninstall log.
I judge that the problem is probably at line 3061 in the log file.
Uninstall.txt
(361.19 KiB) Downloaded 231 times
mli04
I've found the reason so you don't need to investigate any further
Hello Andrew,
Thank you for your follow-up on this.
I'm glad you found the solution and everything is working as expected now.
Please let us know if you have any other questions.
