LrngToFly
appending data to existing REG_BINARY regkey
Hello-
I need to author an installer that appends data to an existing REG_BINARY registry key that a prior installer has created.
Does anyone know if Advanced Installer has a mechanism to help with this or do I need to script something? I see the ability in the "Edit Registry Entry" dialog box to "Append to existing value" for String, but not for Binary.
Thanks for any help or pointers.
Re: appending data to existing REG_BINARY regkey
I'm afraid we do not have an option to "append" something at the end of a REG_BINARY key, but what we can do here is overwriting the value.
For instance, if the value of the previous key was:
and we would like to append something to that, we can recreate the structure of the key in Advanced Installer and then use the following value as the "Data":
00 00 01 11 01 10
After installation, the second value should be displayed in the registry.
