AndyL
Why can't I move this resource to a new component?
I have a component, called "Web.config", which contains two resources: A web.config file, and a web.config XML transform.
I want to split them so the two resources are in separate components, because I now want to apply different conditions to each.
How can I do this? I can't figure it out. When I right-click either resource in the components tree, the "Move to New Component" option is disabled.
Re: Why can't I move this resource to a new component?
Hello Andy,
Most likely, that is happening because the XML transform is applied to that exact config file.
If the option is disabled, that means you can not move it to a new component (perhaps you could try to remove and re-add the files).
If possible, please forward me these two files (the web config file and the XML transform - or some similar sample files) and a small test-case so I can run some tests on my end, although I am not sure I will be able to find a solution to this.
AndyL
I can drag-and-drop it to a different component, but that doesn't solve my problem because I don't have another component that I want to apply exactly the same conditions and attributes to. If I could manually create a new component, then I could move it there. I can't find a way to add a component though, unless I add some dummy file which seems like a less than ideal workaround.
Removing and re-adding the file is a last resort, because I'll have to recreate all the XML transform details via the "Edit XML file" dialog, and it would be too easy to make a mistake. If there's a way to export/import the details of the XML transform, then that might become a more viable option.
I understand.
If adding a file is not ideal, then perhaps you can try to create a dummy registry entry and move it under that.
Besides that, I'm afraid I am not aware of any other workaround, since Windows Installer simply does not allow the creation of an empty component.
AndyL
I was able to solve this problem in the end by manually editing the .aip file to insert a new component entry, and link the resource to it instead of the old component.
Hello Andy,
Thank you for your followup on this and for sharing your solution with us!
Glad you managed to work this around.
MGS
I am running into the same problem. I added a new XML file to "Files and Folders". And now I can't move the XML File to a new component. So the XML file always has to be assigned to a component that already has a file inside. Can this be improved? You force the XML file to be assigned to a specific component anyways, why can't it be a new component?
Johannes
Hello Johannes,
I will discuss this with our dev team to see how we can improve this behavior.
In the meantime, I think I managed to find a workaround for this so you can create a new component for your XML file.
First of all, add your XML file in a separate folder. Then open the Advanced Installer project, go to "Files and Folders" page --> synchronize the folder with the folder on the disk.
We need to make sure that the "Create a new component" option is checked so that a new component is created for each XML.
MGS
Catalin wrote: ↑Thu Aug 24, 2023 3:33 pm In the meantime, I think I managed to find a workaround for this so you can create a new component for your XML file.
Hello Catalin,
Thanks, looking forward to an improvement :)
Thanks for coming up with another solution that's easy to follow. In the end, I decided against going this route though, as this way anyone could forget in the future that the folder is synchronized and adding files there or just delete the folder that is selected for synchronization. Instead I also edited the .aip file and assigned the XML file to a component manually. I am aware that this process can introduce errors too, so I hope you can come up with a solution in the future so that a XML file can be assigned to a new component.
Johannes
Thank you for your followup on this, Johannes!
Glad you managed to find a solution to this and thank you for sharing it with us.
MGS
I ran again into this issue today.
Any news here? :)
Johannes
Hello Johannes,
Unfortunately not. :)
I will update this thread as soon as an improvement regarding this will be implemented in Advanced Installer.
