hpd71
IIS Web Site not going to the correct folder
Hi
I have two web sites I am deploying in my installer. IIS is installed as apart of the installation as a WindowsFeature bundle.
I want the web sites to be in the C:\inetpub\wwwroot\ folder, but the installation is putting them into the applicationfolder, however I am not setting tis anywhere and in my IIS section I am setting the site to go to IIsWWWRootFolder\mpxWeb
It was working find before, but now its not..
What has changed here ??
Re: IIS Web Site not going to the correct folder
In order for me to further investigate this, please forward me a copy of your .AIP File by email at support at advancedinstaller dot com.
hpd71
Here is the AIP file for the project.
mpx Lite.aip
(158.69 KiB) Downloaded 184 times
Thank you for the provided project file.
I have had a look over it and everything seemed to be configured properly.
I have then built your project using dummy resources and eveyrhting worked as expected, the files were placed under the correct folder:
Please make sure that the IIS feature is enabled on the machine you want to install it and that the folder exists.
