Just pasting the snippet of the error here just in case someone sees thsi first
Computing space requirements
Validating install
Configuring CashClubVanilla
Updating component registration
Creating folders
Folder: C:\Everi\CashClubVanilla\
Folder: C:\Everi\CashClubVanilla\PrivacyTemplate\
Folder: C:\Everi\CashClubVanilla\Store_Forward\
Folder: C:\Everi\CashClubVanilla\TerminalData\
Folder: C:\Everi\CashClubVanilla\WalletDocs\
Copying new files
File: data1.cab, Directory: C:\Users\BSULLI~1\AppData\Local\Temp\OPOSDriver\, Size: 4157560
File: d
MSI (c) (FC:68) [04:27:12:309]: PROPERTY CHANGE: Modifying EDIT_1_PROP_1 property. Its current value is 'Extracting prerequisite software
Extracting Microsoft Visual C++ 2010 x86 Redistributable
Extracting Honeywell HSM USB Driver
Extracting Epson H6000 Series
Installing prerequisite software
Installing Microsoft Visual C++ 2010 x86 Redistributable
Installing Microsoft Visual C++ 2010 x86 Redistributable completed
Installing Honeywell HSM USB Driver
Installing Honeywell HSM USB Driver completed
Installing Epson H6000 Series
Installing Epson H6000 Series completed
=== Verbose logging stopped: 6/14/2022 4:27:12 ===
Validating install
Creating folders
Copying new files
File: d
MSI (c) (FC:68) [04:27:12:314]: Doing action: FatalError
Action start 4:27:12: FatalError.
Action ended 4:28:17: FatalError. Return value 1.
MSI (c) (FC:68) [04:28:17:575]: Doing action: AI_SHOW_LOG
Action start 4:28:17: AI_SHOW_LOG.
MSI (c) (FC:28) [04:28:17:689]: Invoking remote custom action. DLL: C:\Users\BSULLI~1\AppData\Local\Temp\MSI54E0.tmp, Entrypoint: LaunchLogFile
Action ended 4:28:18: AI_SHOW_LOG. Return value 1.
MSI (c) (FC:68) [04:28:18:049]: Doing action: FatalError
Action start 4:28:18: FatalError.
Action ended 4:28:18: FatalError. Return value 1.
MSI (c) (FC:68) [04:28:18:049]: Doing action: AI_CleanPrereq
Action start 4:28:18: AI_CleanPrereq.
MSI (c) (FC:20) [04:28:18:155]: Invoking remote custom action. DLL: C:\Users\BSULLI~1\AppData\Local\Temp\MSI56C6.tmp, Entrypoint: CleanPrereq
Action ended 4:28:18: AI_CleanPrereq. Return value 1.
MSI (c) (FC:68) [04:28:18:185]: Doing action: FatalError
Action ended 4:28:18: FatalError. Return value 2.
MSI (c) (FC:68) [04:28:18:186]: Note: 1: 2205 2: 3: Environment
MSI (c) (FC:68) [04:28:18:186]: Note: 1: 2228 2: 3: Environment 4: SELECT `Environment`,`Component_` FROM `Environment`
MSI (c) (FC:E0) [04:28:18:240]: Destroying RemoteAPI object.
MSI (c) (FC:0C) [04:28:18:240]: Custom Action Manager thread ending.
=== Verbose logging stopped: 6/14/2022 4:28:18 ===
As you can see instead of performing the "Doing action: AI_InstallPostPrerequisite" that that highlighted spot (in all other machines), am getting FATAL error. Not sure if something is wrong here. There is another folder which I use for temp folder, that is also post installation and that worked.
