bigshiny90
Creating Patch - max_path of 260
Hi Advanced Installer Team,
I'm having difficulty creating a Patch - I'm adding the 'Upgraded' msi, it is throwing an error when it gets to some files that exceed the windows Max_Path of 260 characters.
Specifics:
The version 1.0 installer has a large amount of image files. A few of these files have pretty long names.
The version 1.1 installer has a handful of these image files changed or added.
When adding 1.0 as the 'New Upgraded', AI starts to process it, but then throws an error 'Error writing to file:'
The path shown is an EXTREMELY long file path - i think AI is extracting the files temporarily to disk and it is using ABSOLUTE filenames. That, plus some extra long image filenames, is creating an error. My guess is a Max_Path problem. (character count of the Absolute path is 263 characters)
So... i have to say, i'm a bit surprised to run into this. There is NO problem with the 'source' installer itself... there are no really long paths in the end.
It is the fact that the Patch project is making everything into an Absolute path that is breaking things...
I'm at a loss on how to fix this... any ideas?
Thanks, I'm attaching a screenshot of the error.
cheers
Re: Creating Patch - max_path of 260
For building patches, Advanced Installer uses a third party tool offered by Microsoft called MsiMsp.exe.
As you already know, the error you are encountering here is a OS limitation regarding long paths.
Maximum Path Length Limitation
Unfortuantely, I am not aware of any method to avoid this, other than using a more compact path.
Please let me know if there is anything else I could help you with.
