RambosRide
BUG: AI 19.5 Dialog Edits Ignored
AI will not use my customized ExitDialog.
Always overwrites with yours.
All my ExitDialogs show "XXXX" in text, in design mode in your editor.
Save, then Clean and Rebuild - at runtime shows yours?!
This is a major issue holding up our release.
Please Advise!
Thanks!
RambosRide
Re: BUG: AI 19.5 Dialog Edits Ignored
[ADDENDMUM]
If I run the "Test Installation UI" from dialogs - my edited ExitDialog displays correctly...but NEVER from a compiled install, keeps showing AI's Exit dialog.
I'm not quite sure why this happens.
In order for us to further investigate this, can you please forward to us the following resources:
1. your .AIP project file
2. a download link for your setup package.
by email to support at advancedinstaller dot com?
RambosRide
I figured it out over the weekend.
I recently upgraded to 19.5
AI software upgrade process doesn't update the AI scripts correctly.
I created a new script on version 19.5 and now edits will work on the ExitDialog on the new script, not the "upgraded" ones.
Which means I have to rebuild from scratch all the AI scripts I've built.
I won't be upgrading to any newer versions of your software.
This is quite strange and I'm not sure I understand about which AI scripts are you referring to.
Can you please forward to us by email to support at advancedinstaller dot com the following resources:
1. your old .AIP project
2. your new .AIP project
3. a test case which I can follow in order to reproduce the problem
