CaMat
Text is not visible on back button in air theme
Hi
I am using Advanced Installer in version 19.5.
I have a problem with Back button in air theme. I want to change it apperance to look like Next or Cancel button so I modified it Display Indirect Property from BackButtons to NextCancelButtons. These properties contains default images for image button for this theme. But when I add text on it, build solution and launch the created installer there is no text on Back button.
Button in Advanced Installer:
Rendered button:
I tried two workarounds but they didn't work:
1) Added new button with the same events as Back button. Works perfectly except in Pre-install UI, because I can't choose WelcomePrereqDlg in display dialog action:
So I can't simulate Back button behaviour on PrerequisitesDlg.
2) I tried add Text control on it, but even it's ordered on top of every control, Back button cover it completly.
How can I add text on Back button? Another themes don't have image buttons as default navigation buttons or they are not suitable for my project.
Mateusz
Re: Text is not visible on back button in air theme
Hi Mateusz and welcome to our forums,
In order to achieve this, you can copy the "Back" button from the "WelcomePrereqDlg" dialog and past it on the "PrerequisitesDlg" dialog.
After that, you need to change the "Visible" and "Enabled" attributes to "True":
button attributes.png (61.46 KiB) Viewed 2795 times
As a workaround for this, you can select the existing "Back" button and copy the event from there:
welcomeprereq event.png (98.46 KiB) Viewed 2795 times
and past it on the "Published Events" of your new button:
my button.png (25.95 KiB) Viewed 2795 times
You can add your desired text for the button from the "Properties" right pane --> "Display Text":
button text.png (93.83 KiB) Viewed 2795 times
Attached you can find a sample project with the above steps. Please have a look on it and let us know if you have any questions.
air theme sample.aip
(28.68 KiB) Downloaded 195 times
CaMat
Thank you for your anserw and help.
Solution with copying event works!
Mateusz
You're always welcome, Mateusz!
