fede071
Enable "Check for updates using Advanced Updater" from command line
Hi everyone,
I would like to check if the option "Check for updates using Advanced Updater" is enabled and if it is not enable it. I am trying to do to this from the command line, but I could not find much in the documentation up to now, only for an update configuration project.
Can such actions be performed from the command line?
Thank you in advance!
Federica
Re: Enable "Check for updates using Advanced Updater" from command line
Hi Federica,
Unfortunately, we do not have command line support for this.
However, we have support for this using PowerShell automation.
For example, you can use the below commands to enable the "Check for updates using Advanced Updater" option:
$advinst = New-Object -ComObject AdvancedInstaller
$project = $advinst.LoadProject("C:\Users\Liviu\Desktop\Your Application.aip")
$project.UpdaterComponent.UseAdvancedUpdater = 1
$project.Save()
For more information about this, you can refer to the below article:
PowerShell Updater component
