sakis_s
Convert EXE to MSI & silent install with pre configured actions
Hi there,
Is there any guide of how to install software avoiding installation steps?
I have an exe file that i want to install to about 100 desktops.
This exe when installing it needs to click next button, accept terms of use and after finish installing it promts to agree with terms and finally login to your account. I need so much time to install this app to all these desktops.
My goal is to convert this exe to msi so i can remotely silent install the software with pre configured settings for the users to not prompt for actions and login in the end. In other words to be ready to use after remote installation.
Can i do that?
TThank you,
Sakis
Re: Convert EXE to MSI & silent install with pre configured actions
Hello Sakis and welcome to our forums,
Yes, it is possible to achieve that using Advanced Installer.
Now, does your .EXE file already have parameters that can be passed to it through the command line to perform all those tasks?
If the answer to that is yes, then you can add your .EXE as a prerequisite in a new project and pass the parameters through the "Install Command Line" fields from the "Prerequisites" page --> your prerequisite --> "Setup Files" tab.
For more information about this, please have a look over the following article:
Convert EXE to MSI - Create an MSI package from EXE
